Have you ever bought a tractor and thought you got a great deal, and then you start fixing a few small problems, a you find more and more and then big problems?
Well I bought one. Jd 520.
I got it starting and running good. Has power steering, and when the throttle is increased, the front wheels go hard to the left. I loosened the 4 bolts and tapped the valve, started tractor and went to the right. now it seems there is no assist at all. Fluid level is a little low. And noticed a fluid on the belt, looks like the front seal on the pump is leaking.
I would like to get this to work for this summer and tear pump and front end a part next winter. Is there a way to increase the pressure? Open to all advice.
What is the number of the manual that explains this system?
