John deere A
Mogster
I have a 1952 A. Were can I obtain oil coupler for the powr-trol to run some hydraulic cylinders. And some shear washers.
The couplings, A3134R, are still available from Deere for about $180.
The shear washers, A3141R, are still available from Deere for about $30.
Or check on ebay, and GOOGLE the part numbers, as well, to see what's available out there used.
You don't need shear washers for that type of plug. There are usually couplers on Ebay. The Classified ads here are a goood place to look also. Put your own ad on.
Steiner's have the hydraulic fittings cheaper if you don't want to pay the Deere price. Several different ones and shear washers if you need them. I have their 2015 catalog and fittings prices range from about 30 to 60 dollars. Been to their store a few times, live about 15 miles from there.
Is it not easier to add the connections to the side plugs on the right side of the PowrTrol unit as viewed from behind and use quick-connect hydraulic valves? Maybe what you want is not that, but I know that it works very well for the operation of a loader.
