JD 3PT DISK
Doug Shaw
WHAT MODEL DISK IS THIS?
No, not rare! Value probably dependent on condition! Probably as good or better than light duty short line 3 point discs available new!
It is a 3 point hitch version of the well known JD KBA wheeled disc.
JMHO, Dave
It might be considered more desirable than the short line discs, as it has some built in flexibility. That being desirable on uneven ground.
Again, JMHO, Dave
KBY is right on , looks to be an 8ft.; 3pt.hitch looks to be redone to cat.I from cat.II hitch bar style as in Jim's first PC. print.. [as 8ft. only came with hitch bar] ; cat.I hitch in ( Jim's second print) only made for 6ft. disk.. Doug: your hitch looks to be remodel to cat. I similar to PC. print of 6ft. disk... We use a [rigid] 6 ft. KBL; also have a 9ft. KBY; & a 14FT. KBA.. they'll each do dif. work in same field cond. // Your's looks to be in very good cond. ...
