Mike M..piston update
RandyB(MI)
Hi Mike. Had those m/w pistons measured again. Then I found the actual figure the first guy wrote on the box. They are 4.720 for a .045 over bore which as you said would be 4.732 for a clearance of .012 which works out just right. Thanks again for clearing up my brain toot. RB
Now that all sounds like I remember it. You will be good to go if you happen to have an old worn out std. bore.
Now believe it or not ( I could hardly believe it at the time )I rebuilt one with those pistons in it and it was dynoing about 35hp !
