4440 hydraulic line
There is a plastic hydraulic return line that runs from under the cab and then to the front of the tractor. The line is broken and I'm leaking hydraulic fluid. I can't find where it hooks up under the cab, have the panel out below the clutch but just can't figure out where to hook it back up. Thank you.
Charlie
It goes to a fitting on top of the clutch housing, if you remove the panel around the dimmer switch you can see it better,, an ornery place to get to,, would help if you were Double Jointed...
If the wheels are squeezed into 30" tread it's even worse,, I'm no little guy ether...
