67 4020. 3 point
Yes, but they are not completely interchangeable. The yoke at the top has a couple of "ears" where the adjusting handle rests, so it will not rotate accidentally. There is a left side and right side upper yoke, to avoid the ears hitting the tool box.
If your rod is frozen in the lower yoke like mine was, it took a 36" pipe wrench to get it out. Be aware that you need to run it in first, as there is a cross pin in the bottom that needs to be driven out; then you can unscrew it from the lower yoke. Good luck.
