MaverickM23
Had our 5403 in the shop to put in a block heater. Drained the coolant from the bottom of the radiator and put the block heater in. Filled with coolant and started the tractor and ran it till the temp moved to the middle of the gauge. So I thought all was well. Tonight had it plugged in and it heated up and started easily so I took it to grind feed but when I was done the temp was in the red. I shut it down and cracked the cap thinking it had air in it and it had some pressure so I started the tractor back up but the temp stayed hot and it only moved down very slightly. The top hose is hot and the bottom is ice cold I cant get it to circulate at all, the bottom hose doesn't even feel like it has coolant in it. I opened both hose clamps on the lower hose thinking air that was trapped could escape but no luck still wont circulate, I'm thinking its a thermostat now, is my thinking right on this?
