I am installing a Westendorf loader on my John Deere 650 and cannot get the loader to operate. My tractor had no additional hydraulics - no power steering, no Selective Control Valve. I purchased the loader new, direct from Westendorf, with all of the parts, including the control valve. I installed the loader per their instructions along with the help of John Deere's technical manual. Everything installed with only one issue...
The problem I have is the loader will not lift. The loader will only lift when the 3 point hitch is lifting. The loader will drop, due to weight/gravity, when directed to drop by the control valve. It will hold once lifted.
I have installed the power beyond plug behind the outlet port on the tractor, per Westendorf's instructions and per JD's technical manual for the tractor. The tractor acts like the plug is NOT installed. The plug I used came from Westendorf, just a simple plug. Is the plug from John Deere something special?
I took the tractor to the local Deere dealer who tested the hydraulics and found pressure, relief valves, and flow to be within specification. They did not indicate the plug was wrong or the wrong type.
I have narrowed the problem to one of two things:
1 - The tractor is somehow bypassing the auxiliary circuit? The 3 point hitch works as normal all of the time. My understanding is the purpose of the power beyond plug in the tractor was to force the fluid through the auxiliary circuit, then back to the 3 point hitch after the auxiliary circuit.
Here is what has me perplexed about the tractor --- If I leave the power beyond plug behind the outlet port of the tractor, disconnect the lines to the loader circuit, and replace the two plugs blocking the out & in ports of the auxiliary circuit on the tractor, the 3 point hitch [u:1b3cb26e01]still works[/u:1b3cb26e01]. Based on the technical manual & my understanding of the system, the 3 point hitch should not be working if the power beyond plug is in and the two ports are blocked. It seems my tractor is not properly routing the fluid through the auxiliary circuit, even though the plug is in. Anyone know why not? How is the fluid getting around the auxiliary circuit back to the rockshaft?
2 - The control valve Westendorf sent me may be the wrong type of valve? They have sent me two valves because we thought maybe the first valve was bad (The John Deere dealer's suggestion). My understanding is when the Control Valve is activated, fluid should route through the loader to the out port & dumb to the reservoir. I only get dump to reservoir when the loader is dropping (due to gravity). I do not get fluid dump to reservoir when I ask the loader to lift. This indicates the system is not putting pressure on the loader circuit when asked. The JD Tech manual states the system needs an open center valve. Could I have the wrong type of valve? Is it possible the valve I have is open to the power beyond port & the out port when activated? If it is, wouldn't the fluid take the path of least resistance and just dump through the rockshaft instead of going through the loader?
I have been working on this installation for 4 weeks, which should have been a 6 hour job. Any ideas or thoughts are much appreciated.
