I removed both gears from the gear reduction cover for access to the main bearing on the right side of the tractor. I wired everything up in order for installation. After I installed the inside gear I realized I left the outside gear laying on the bench with no indication of which way goes out. The first photo is what I believe to be the inside of the gear that goes towards the inside gear. The second photo is what i believe to be the outside of the gear that goes towards the gear reduction cover and bearing. The Third photo is another photo of how I believe it should be installed. Can anyone confirm that I am correct. Thank You,
Ryan
Ryan
