tomstractorsandtoys
I am working on changing a 720 from narrow to wide front and and need some help with the bolts. The narrow front uses four bolts part number 19h1862 which are 3/4 x 2 1/2 the wide front uses two bolts part number f3638r but the parts book gives no specs. Online does not list specs for the f3638 either. I do not have the wide front here to measure the center steering arm thickness. Can anyone tell me if the bolts are the same length? I am tearing the power steering apart now to replace the bottom seal and at sometime in the tractors life it had to long of bolts in the front end that damaged the bottom casting some. Thanks Tom
