A tractor Governor shaft removal
8850dave
I am trying to remove the governor shaft from my 1952 A tractor but the gear does not clear the case and the governor shift shaft. I am doing
something wrong or do I need to remove the case first ?
Did you take the screws out of the fork and then remove the fork ? Don't loose them. Stuff some rags in there and use magnetic grabber ? Been a long time since I did one like that I'm pretty sure I have done them on the tractor, but you may also have to pull the fork shaft up ?
take the set screw out of the lever on top of the gov and then rotate the fork out and back into the case and then it will come out
