Cab kit for 4440
Id also suggest getting the kit that is plastic backed and the snap on style post covers. It takes a great deal of pain out of installing the kit. It keeps the aerosol glue out of the cab.
I"ve done two of the Fehr kits- very well cut, easy to fit. I take the seat out, then wire wheel to clean off the adhesive. When checking prices, some kits do not include new adhesive, but sound cheaper. Learned a tip here recently...omit adhesive a few inches from the window edge that you need to slide the foam under....
FYI, Fehr can make you a 4440 kit in brown like the later tractors. I put one in my 4640. 30 years from now someone will write Mr. Thinker and ask if Deere made any 40 series tractors with brown interiors.
I ordered from Fehr today and also got a kit for a 4320, seem to be real nice people. Thank all of you for your help it's much appreciated.
Charlie
Four bolts, under the seat cushion. The mechanism stays in place, and there is plenty of room to work in.
