3010 air cleaner grommet
craigco
I am looking for a new air cleaner
pipe grommet for a 3010. All I can
find on line and in catalogs say they
fit 4020s and alot of 2000 size
tractors. Will this fit or do I need
to go to the dealer, or do you know of
a supplier that has them?
Do you mean the black rubber piece that goes around the pipe as it comes through the hood? If so, you should have no trouble finding one. I ordered two of them last spring. Sorry can't remember which supplier but if I found it online it can't be hiding too much. Check under 3020 parts.
Gas or diesel, dealer can get either, NOT cheap, gasser is MUCH higher-priced, for some reason.
The gas is much smaller and only used on 3010 gas. The diesel is the same as both 3020 gas and diesel,2510 gas and diesel and the 4010-4020 gas as well. Tom
