barry county
I just had the cylinder head surfaced and magnufluxed at a local machine shop. It's a newer
replacement head according to the part number, B2871R, as it does not have replaceable push rod
tubes. I installed a new head gasket and new lead washers, torqued to 105 ft lbs. Ran for a while
to get warm, re-torqued the head to 105 ft lbs. Ran again to get temp up to operating range. My
problem is, there is coolant leaking out the back side of the head down at the bottom. It's a very
slow leak, but none the less, IT LEAKS! Any suggestions? Could the head gasket have been put on
backwards? I installed it with the "crimped rings" around the cylinders facing toward the head.
