FarmerCline
New User
I have a 1971 JD 4020 powershift that I bought without looking it over first that has turned out to be a money pit. When in neutral the tractor will keep moving as if it is in gear but will stop if I press the brakes. It does this in both forward and reverse depending on which direction a was moving before putting it in neutral. What will it take to fix this? JD dealer said it is likely a transmission problem and will require splitting the tractor.
I have already spent way too much money on this tractor but at this point I have done so much already I might as well finish fixing the rest of the issues.
