1020 hydraulic leak part 2
36 A
Buckanddeere I might have taken to much apart . But there are things that needed work anyway . Both side panels were loose on the radiator . And the water pump needs replacing . BUT I blew threw the hose and it was plugged it goes to a tank above the pump . But there was also some moisture at the seal . I ordered a kit from deere $43.99 .
