Was driving a 4440 the other day and after topping a hill unloaded, it got hot and put out a lot of steam or blowby from underneath (not sure what it was). I throttled back and started to pull off the road. It labored the engine and smoked black out the exhaust. I shoved in the clutch in and it died. It would not restart. The next morning it started again after sitting in the shop but it started very hard.
I got it in my shop and checked oil pressure on it tonight. 30 psi at cold idle. Went up to 45 psi at full throttle and after running for a couple minutes, idle pressure was about 25 psi. It still starts hard (like it's cold outside even though it's been in a heated shop) but sounds good when it's running.
Aside from a manual, where should I start on this thing?
