Clutch fork shaft
franknpdl
I need a new bushing for clutch fork shaft on my 720 diesel.part num. f 1246 r does not come up anywhere.thanks in advance
It's still a good number with DEERE (when entered in the proper format), but a bit pricey...
Part Details
Part Number: F1246R
Part Price: $43.24 USD
Description: Bushing - BUSHING
Package Quantity: 1
Specification
Weight: 0.13 LBS 0.06 Kg
Inside Diameter 1.065 IN
Outside Diameter 1.187 IN
Length 1.750 IN
Hole Size 0.00 IN
Material ST/BRZ
I recomend measuring the shaft at the largest point with a micrometer and measuring the bore where the bushing goes with a snap gauge and micrometer and have one made from oilite. This will tighten up the clearance and remove some play. Dont forget about the small bushing on the bottom.
