John Deere M
JDM info
New User
looking at a great tractor with fence row equipment 2 bottom plow, cultivator, sickle bar. Has 3 point conversion but eq. is old style have no idea what it needs for hook-up. Any sites, info., help thanks.
If the conversion is the drawbar extension type you can still use the orig equipment or modern three point equip. You will need the hanger brackets that came with the orig plow and cultivator. Not sure how the sickle bar mounts. James Howell has posted a bunch of pics of his if you do a forum search.
Type john deere m hitch in the search box at the top of the page and you'll see a link to mine. Here's James's if the link works. With ours either type equipment can be used.
If it has the individual arms on each side and the factory two point was removed it can no longer use orig equipment.
Poke Here
