1020 hydrolic leak
36 A
The seal on the pump in front of the motor is leaking . What's the best method to get to
this? Do you need to remove the pump or spilt the tractor at the radiator ? Thanks
From what I could tell by trying to look up in there the shaft was all shiny wet . Just
looked like that's where it was coming from . I pulled the radiator because the side
panels had came loose . Now I can remove the pump . And the water pump is loose also.
Anything else while I'm in there ? Lol oh is there a drain on the pump or just let it run
out from the lines ?
It's not just slobbering it's many drops a minute . I have almost everything off but one big oil line it's stuck to the pipe . Someone has had it apart before me and put a little twist in the line . Now I'm wiggling the nut a little bit and no go . Do I dare to try some heat ? So darn close !
Got it pinched the line with a vice grips held that and pulled the wrench . Is the weep line the little plastic line in the bottom front right corner ? The plastic Farrell nut is white as can be while everything else is covered in grease . Don't look like much from the shaft .
Before yanking everything to bits. Ensure that weep line is unobstructed from the front pump fitting to the transmission case .
