open center-closed center
Leroy
I have never had a 3010-4010 type but I see all the time mentioned about open or closed center hydrolicks. I do not understan them but my question is witch would be like the A & B'tractors that I had. Open or closed on the 2 cylinders?
Open center. The oil is constantly moving through the hydraulic system,unlike a closed center system where the oil is only pumped as it is needed with priority to the steering and brakes
Open centre---full flow, zero pressure when not in use
Closed centre---zero flow, full pressure when not in use, kinda like the water pressure system in your house
Simplified explanation that describes most systems.
Ben
OK so they should be opencenter and I suppose all the 2 cylinder tractors as well? Also the letter series Farmalls and what about the number series Farmalls?
Letter series Farmall would be open center, as would a 300 400 series, I do not know about the bigger ones.
