JD 'A' and Farmhand loader
DeltaRed
I just aquired an F-11 loader.It will fit between the wheels. Will it fit around the flywheel and clutch pulley?The tractor is a '44 AW. Thanks.Steve
It ought to fit, with all the other things you've built this should be easy.
But my concern is. Do you really want to put that on a tractor with a hand clutch
& no Power steering + a revamped steering linkage & wide front?? All I've ever run
are Hand clutch tractors I don't have a issue with one, but it's going to steer harder
with that loader on it.....
I'd rather have another M Farmall. But I have the A,and no money. As for the power steering,I've never owned a loader with power steering.And the hand clutch ,I'll just deal with it.I wont use it often,I dont feed with it.I'll get by till something else comes along.
I've seen an A with a Farmhand loader on it. I don't know the model no of the loader, but I assume it's probably similar to the one you have. I've probably got a picture somewhere. But I know it can be done.
Unfortunately I have NO pictures of when I owned and operated a FARM HAND HAYSWEEP first on my JD "R" and then on my JD"AR"
Bob..
It should fit OK ; Here's a pic of F-11 on a 70 ,
Don't have this tractor anymore, the loader isn't a farmhand, but someone's homemade copy of a dual.
Have a F11 on a 620 now. Fits, but the chains are really (scary) close to the cylinders when the bucket is on the ground.
Man that picture scares the devil out of me, unless you're driving in reverse. Some years ago a two neighbor kids were fooling around doing the same thing. One ran over the other and killed him. SAD!
