JD 2030 Clutch Shaft Splines (Picture)
Hello there! During a clutch replacement on a 2030, I ran across the wear on this clutch shaft. I advised the customer to replace the shaft. He wants to know if he can get ~1,000 out of it with a new clutch the way it is. Opinions? :D
You wouldn't advise replacing it? It looks to me like it would wear down the female splines on the clutch disc quickly.
I would replace it,,but I have seen worse,and they weren't causing any extra trouble, I think that shaft will pull out the front,, I know it will com out the rear, but that would be another split...
(quoted from post at 16:55:20 11/19/15) I would replace it,,but I have seen worse,and they weren't causing any extra trouble, I think that shaft will pull out the front,, I know it will com out the rear, but that would be another split...
I [i:64acc334aa]think[/i:64acc334aa] I remember needing to split the clutch housing from the transmission to pull the clutch shaft...memory fuzzy.
Thanks for the input!
I'm thinking the inner bushing keeps it from coming forward....I just had a 2030 apart and it came out the rear for sure...
(quoted from post at 17:58:26 11/19/15) I'm thinking the inner bushing keeps it from coming forward....I just had a 2030 apart and it came out the rear for sure...
3 T23062 ROUND RETAINER ...possibly...
I would wait until you have to split it at the tran.
It will work OK the way it is but might make a little
noise at low speed.
