Fuel Shutoff John Deere 60
kandrelly
New User
This message is a reply to an archived post by Bob Harvey on May 06, 2013 at 10:42:02.
The original subject was "Re: Fuel Shutoff John Deere 60".
Does anyone know what size the fittings for the oil pressure lines are? I am going to put in a manual shutoff, but I want to connect the two oil lines so my oil pressure gauge still works. I want to get a connector, but I can't find one small enough. And I can't order one online, because I can find a fitting that fits so I know the size. Please help! Thanks
Those lines have really weird fittings on them. You could use the factory tee and leave them connected together there and then get an 1/8" pipe cap and put on the side that screws into the bowl to seal it off.
That will work. Thanks! I wasn't sure what I was going to do about the oil lines. I really want to keep the pressure gauge too, so that should work!!
