Counter-shaft assembled on the bench to make sure the parts are all in the correct orientation. On the RH side, 2nd & 5th speed, then pinion differential drive gear, spacer, and 1st & 3rd speed gear. 2nd & 5th and 1st & 3rd both have a longer hub side on each gear. Do both of the hubs face inward? The picture in my manual isn't totally clear. Since this assembly will be pressed together in the transmission case, it would really be nice to verify they are assembled in the proper orientation. This transmission project is to replace bad bearings...which turn out to be quite expensive.
