after all the posts I've read here and over on the pulling forums, I am needing a great source for a set of .125 over pistons for my freshly bored late styled G block. I am assuming high compression aluminum ones are the answer but I am having a hard time locating them from a reputable source. I don't intend to pull her, just wanted to make it bark a little more than stock since the cylinders needed cleaned up that much. I also ported out the head a little to match the manifold. Nothing extreme, just looking for the piston set and trying to match up a head gasket since the bore job.
