JD-1944-B-NJ
New User
I removed my Wico C magneto today. I need to replace the shaft bushings as my rotor is hitting the cap.
While inspecting, I was able to gently remove the Magneto Drive Flange. Should this be pressed on or come out so easy? I ask b/c the machine key dropped out and I can't get it back together.
Does this mean my shaft is worn or am I just a deere idiot? What's the trick of getting back together?
As always, THANK YOU!
