Thanks to Tx Jim I think I have Most of the stuff I need to get the loader off of my rear hyd ports. I just want to make sure that I have everything correct BEFORE I start tearing this thing apart to do it. I want to do this at the same time I change all of the fluid and filters. I have the T fittings for the right side already.
So based on what I have been told and read, the supply side will come off the fitting right behind the brakes using a T fitting I purchased. Please let me know if I am mistaken on that.
The return line can either come off of a filter cover OR be plumbed in near the filters. I have the ported filter cover but I would prefer not to use it if I do not have to unless it is better. If it is better should I put it on the front or the rear filter spot?
If I plumb directly in, there are three lines on the rear side of the filters. I tried to take some pictures but they didn't come out to well since I didn't remove the battery box. What I need to find out is which line should I plumb into here? There are two LARGE lines and one small one in the middle. The furthest right (rear) and most accessible line goes almost straight up. The smaller line in the middle goes towards the front of the tractor. And I dont remember where the left line went.
Attached are some images of what I am talking about here.
And last, if I am looking at the rear hydraulic ports standing at the rear of the tractor. The loader is currently plugged in to that. Which side is supply, right or left?
I am going to do a complete instructable on this for future people with video pictures and written instructions as well. Once I get it done I will post a link to it and a link from it to here as well.
