1965 JD 4020 flywheel
I'm rebuilding the powershift and decided since it is apart that it is time to change the rear engine oil seal which is simple with the proper JD tools...I mounted the flywheel and no where in my JD service manual can I find the torque spec for the four bolts that attach the flywheel to the crank. It keeps referring me to another section of the manual. Came someone help me out? Maybe someone can tell me the page #.
Thanks
SM-2039 dated Apr. 1967 Page 20-5-6 under specification for 4020 Engine cap screw torque 4Th. line down Flywheel-to-crankshaft 85 Ft-lbs. When I did my 4020 that is the torque I used and it has been 5 years now and is still ok.
Yup, the blue stuff, loctite 242. When I took the flywheel off the bolts just did not seem to be tight enough to me, but I would guess they had the 85 lbs of torque as recommended by the manual.
