4020 Hydraulics
I have a 4020 with a Hydraulic disengagement lever on the left side of the steering cowl opposite side of the PTO lever.
An operator flipped the lever to disengage the Hydraulics because he was having a hard time starting it and now that it started we can not flip it back to get hydraulics. we have no steering, PTO, nothing.
Could someone help?? How to get hydraulics back.
Thanks
Button on dash , see pics, On early models, 68" older; pull button, while holding lever back & release forward.. On late models 69" newer; push button , while doing same with lever.. If button is missing or broke , crowl tin will need to be removed to get at latch....
Thanks line man!! That was the trick. Now I'm kicking myself in the rear for not figuring that out....well, I guess I did thanks to you! Have a good day!!!
The lever does a bit more than just a disconnect for the hydraulics. It actuates a clutch on the flywheel that disengages the entire transmission from the engine.
