9660 STS header problem
jvm
New User
Had the deere dealer here all day Put new mother board in Now all things checkout but when you tilt the head to the left it does not respond tilt it to the right and it works just fine You can tilt it manually but will not work right in automatic Wondering if anyone has heard of this They called into tech but no help yet.
i had an issue once with a run of bad boards. Tech support didnt know/admit it till we swapped out the 3rd board. This also assumes all electrical connections were chased down to the mechanical component.
