Ok guys I need yalls help !!! Got a friend that has a 2020 thats a late 60's model. its been having a issue where when you turn the key off (no kill knob) it will still run for a few min.
then when you try to start it sometimes fires right up but sometimes not. he was told that there is a plunger inside the injector that might be sticking and to tap on the injector while turning the it over.
well this has work for him for a long time until yesterday.
he killed and could not get it to start, would turn over but not fire off. anyways he pulled the wire going to the injector and when he went to put it back on it though fire and now it will not even turn over unless you jumper the starter solenoid but it will not start just turns over.
any help,like maybe a relay or a fuse that could have been shorted out.
thanks
thanks
