I recently purchased a Deere 2150 tractor. It has very low hours (600), but had been sitting unused in a shed for a number of years. The only significant problem is that the lift arms drop immediately when I turn the engine off. Here are some observations I've made;
1) The rate-of-drop adjustment works fine when the engine is running. I can lock the arms in an upright position with the rate-of-drop knob and then the lift arm lever has no effect. So things are normal with the engine running. If I shut off the engine the arms will drop, though they drop more slowly if the rate-of-drop is tightened down. So the fluid is finding an alternate path.
2) If the arms are down (with engine running), moving the load compensation lever from minimum to maximum and back causes the lift arms to lift and drop a few inches. According to the manual, this should not happen. (This is one of the tests JD recommends to see if things are operating normally.)
Seems like maybe a relief valve may be stuck somewhere, which would seem consistent with the tractor having sat unused for a long time. My guess is that this repair will require a trip to the JD dealer, but I'm wondering if anyone has any ideas. My fear is that the repair guys won't be old enough to remember much about the 50's series hydraulics.
Thanks in advance.
Thanks in advance.
