John deere A-B-G Front Wheel Weights
CTPopper
New User
Just came across a set of the rare A1827R front wheel weights. What I noticed is that there seems to be two different weights with the same casting number. One set has a recessed face and 6 holes for mounting while the other set look very similar ro the B2016 front wieghts. The set without the recess has 3 mounting holes. Is one set more desirable thatn the other? They are both listed to fit the same tractors and the weights are the same.
Any help is appreciated.
CT_Popper
Very Interesting. I have pictures of the two different versions of the A1827R. I have uploaded a picture of each version to the blog post gallery wherever that is. I would really appreciate any pictures you may have of the two versions of the A1827R. The highest resolution you can obtain. I'm having real problems finding a picture of an A1826R front wheel weight which is for spoke front wheels. I may have found one on a BI in Walter Keller's collection but I am unable to read the casting number in the picture. I will probably need to contact Walter directly. Another weight I'm having real trouble finding a picture of is a H774R, 4 of which are used on the front of a HN or HNH. They are 20 lbs each. No pictures at all of that one.
