On my unstyled A, I fired it up sounds good, but at high throttle the steering wheel and left tire vibrate like crazy.
Also it leaks water behind the water drain up high somewhere in the block or gasket or something and drips down that v taper to the water drain plug.
I just got this thing running. Finally got good oil pressure, but now these 2 problems. Does this tractor need to go back into the garage and rebuild the engine, or is there something I am over looking?
Thanks
Thanks
