My friend has a 4230. Last year he had the remote scv's rebuilt by a retired JD mechanic. This summer he has it hooked to his discbine and it blows a hose out of the remote. Later, the remote starts leaking so he has it rebuilt, again. Mowing it develops a hyd leak at the main pump. Blows out a o-ring on the cap which holds the piston. We bring it to the shop, get it fixed. Take it to the field, blows the same o-ring out again. He gets a gauge and we check the pressure at the remote, 2900 lbs. Again we bring it to the shop. I took the de stroke valve out and there was a washer under the spring. Put it back together without the washer and psi dropped to 1800. What would cause this spike in pressure?
TimS, he is ready to send the pump to you. Anybody had this happen before?
