RedBarnNate
We are installing a new fwd/neutral/rev cable on a 5520 open platform tractor with the powrreverser transmission.
Other than making sure that full range of travel of the hand control lever & corresponding shaft/arm on the side of the transmission are correct, is there any other adjustment needed?
Also, if there is a lack of movement of the tractor when reverser hand control lever is in forward position, tractor is stopped, clutch pedal is being released, until almost the "top" of the clutch pedal travel...then movement begins...is that an adjustment issue?
I have TM2048, but not TM2049...
