What is the correct way of adjusting the range of motion on the throttle lever?
I have the linkage to the carb set correctly from the help of others and on here, but now I want to adjust the lever range, since it is adjusted currently full travel both ways. Also, you can pull it so far back, that if you were going to turn at idle, not that you would often, you would slam your knuckles against the lever.
Thanks.
Thanks.
