Needing hydraulic pump drawing
hrbburn
Does anyone have a print or picture of the front hydraulic pump they could share? I have a leak someone but can't see where it is coming from. Also there appears to be a bolt missing just to the right of where the top hydraulic line comes in. The longest bolt I can get in there, because of the radiator is 2.5". Not sure if this is actuall suppose to have a bolt or not. Can you shed any light on this for me?
Thanks,
Bud
About half of the bolts are recessed allen heads. The rest are visible allen heads. It's probably coming from a line. I would try tightening the oil lines and cleaning with brake cleaner. The small line has a compression fitting and the large line has a cork seal. Here's a pic. As you can see there are 4 different size bolts in there and they can't be interchanged.
TOM%20Pump.jpg"width="650"
Thanks guys, had not seen that website before, but it has everything I need. Thanks again for taking the time to help. My next big need is finding someone coming from South Carolina area to the Portland Indiana tractor show this weekend. Need two wheels hauled up.
