lower lift arm leak
ZANE
2020 leaking hydraulic oil at the lower lift arm to differential.
How to fix?
Any pictures?
Zane
Load shaft seals are leaking. The lower links go directly onto the ends of the load shaft. After you change the seals use washers to shim all the side to side shuck out of the shaft.
