60 MFWD plow pics
tim s
Here are a few pictures taken after the plowing test last night, the wheels seem in too close, but they are where they need to be..
Sure does look good to me, all I'll say this tractor might need is a Front bracket for
suitcase weights some day. All I know if someday it sports one, it will be a creation that
looks original & uniform .
Tim, if that is a 14" plow you need to have your wheels set 24 1/2" from center to inside of tire. If you are going to plow deeper you might want to add an inch to that. I'm sure you know that already....:) Mike
No expected problems,,she is ready to go...and so is the plow,,it's all shined up and ready..
It steers nice and is about like any wide front, not as tight of a turn as a tricycle..
I sure like that landing lever on your 60 drawbar! You don't see many of those. Of course, this will give you the adjustment you'll need if you get on varying depths and on hillside plowing. As long as the front bottom is cutting 14 inches (assuming your plow is a 14") the wheels & hitch are right in terms of the plow. It looks like a real fun setup!
See you in Rantoul,
Tyler
