2010 diesel
rick deere
I bought a 2010 diesel, had to have diesel pump rebuilt,put in on couldn't get fuil to come out of pump even when pulled.Pulled it off took it back, bench tested , couldn't find anything wrong with it.Put it back on same problem. Then we put an electric fuil pump on it started right up.Now should I take electric fuil pump off or will it hurt anthing to leave it on??????Thanks Rick
I think you 2010 will be fine leaving electric fuel pump attached. You must have poor fuel flow from the 2010 fuel tank to require an electric pump to enable engine to run. Is the fuel tank vent plugged up?
I have plenty fuil flow,thought maybe sinse I had the diesel pump rebuilt might have not gotton all the air out,should I try it now sinse got it to run without electric fuil pump??
I took electric pump off today wouldn't start good, put it back on starts like my truck and runs great, so looks like I'm gonna leave it on.I will try to conect it to the key switch so it gets turned off same time key switch does.Thanks for your help.Now i might put all the sheet metal back on it and service it and than try to put a price on it, it's a neet little tractor.
