Delco Distributer shaft wear
bigboreG
I have never rebuilt a Delco, other than the ignition components. The one on this '47 A has an AWFUL lot of in and out play, and even worse side to side. Is there bushings I can replace? If so how many? Anything else I should look for / replace? Thanks in advance.
1917207 is the bushing, 1912765 is the advance springs available from Deere. You need 2 of the 1912765. Just received some last week. Yes this is the correct part number.
