630 radiator
brokeagain
New User
Need direction, how to proceed. I am down to removing steering support bracket and would like to know what parts of steering shaft to remove. Yes, everything is rusted and corroded. Please help, all recommendations appreciated. This is my holdup on pulling radiator. Since the cores are readily available, many have done this. Thanks!
with the steering lines removed take the 4- 1/2 cap screws out and remove the steering gear assy. now you have some room to get rad out if you need a good core i have one
I thank you for the response. Before seeing it, I took the chance and removed it. Pulled radiator, rewelded exhaust support, and scraped gasket area. Now to put it all back together. Thanks again.
