B axle shafts
41106
Will axle shafts from a '37 interchange into a '43 rearend??....wanting to change so I have the correct spline for some spoked rims. Thank you.
I think the DIFFERENTIAL housing is the same bolt pattern , why not change the whole thing housing gears and axles at one time. Look into it.
I'm trying to get my plans together to make a 6 speed unstyled B and axle seals definitely need changed and was hoping to swap axle shafts while I was at it so my spokes fit. I realize it will take some effort, just wondering IF they fit. Thank you.
