1010W John Deere
I'm stumped, the electrical system on a 1010 JD is not that complicated, but I can't get the spark to go past the points. Put on new wires, cap, button. Also which way does the coil go on. The "original" one was pointed down. Not real great at the mechanical part of things.
Spark doesn't really go past the points. The coil neg - is live with the ignition switch on. The points "ground" the coil's + to chassis to complete the coil's primary winding path.
