jonwymillj
I have a 46A on my 4020(some day I want to upgrade to a 148 or 158 but this came on the tractor) with a prince pump on the mid pto. And a cross three spool valve. My problem is that when I pick up a load of bales it wont go more than a couple of inches up or tilt back at a time. When it is empty it almost always works fine. Sometimes when I just grab 2 bales it lifts fine and other times it doesn't. They are close to the same weight of bales. I switched pumps and tried aonther pump no change. I can't see any bad or pinched hoses. I just replaced the high presure from the pump to the valve. My guess is the seals on the spools are starting to leak bye??? I have noticed the loader getting weaker and controls getting worse over the winter plowing snow. Do you guys think I am on the right track? I tried calling Cross to day but did not get through try again next week. Thanks
