520 Voltage Regulator
I am replacing the wiring harness on my 520. The voltage regulator is mounted on the generator with the terminals facing out. Should it be mounted where the terminals face toward the fan shaft because of the location of the white wire from the battery? I have an A the same way. I have a manual, but I cannot tell form the pictures.
My JD 520 has the Voltage reg. terminals facing the FAN DRIVE SHAFT. White wire closed to the Genereator Pulley.
