'37 JD A belt bully side crank thread
I have worked on a 37 & don't own a 37 just know that none of ours are lh thread..
Standard right hand thread. Remember the driver needs to go on the right splines when it goes back together. Also that driver comes off hard as the splines are tapered. There are two clutch discs , one on each side of the driver. Ron Mn
(quoted from post at 10:43:11 07/27/15) Standard right hand thread. Remember the driver needs to go on the right splines when it goes back together. Also that driver comes off hard as the splines are tapered. There are two clutch discs , one on each side of the driver. Ron Mn
Thanks Ron
