Trans-Hyd sight glasses
MoMaks
New User
I just got a 2012 JD 5083e open station utility tractor with a JD 553 loader on it. Back by the pto shaft there is two trans-hyd oil level sight glasses one above the other. The manual says bottom (add) glass should always be full to the top but I wonder where the oil level should be on the full (top) glass? I hope someone here on the JD forum knows. Thanks in advance. MoMaks
As stated above just visable in the bottom of the top sight glass. According to manual add fluid when level is seen in lower glass.
